Power UP 3.0
Ready for an early Christmas present? We are super excited to reach this milestone in our digital system in play, with LEGO Powered Up 3.0. With this update we hope to further empower your creativity and enable all of you to rebuild the world. Also, we have a fresh new look!
What’s new?
· For those of you that have more than one hub, good news, you are now able to connect, address, code, and control multiple hubs (up to four actually).
· The app now fully supports the new LEGO TECHNIC hardware. You are now able to connect the new LEGO TECHNIC hub, and use the internal tilt sensor, as well as the new LEGO TECHNIC motors. For the real techy ones, the app can read values from internal sensors (orientation (X, Y, Z), and acceleration (X, Y, Z) of the TECHNIC Medium Hub (Hub128). From the app you can pair motors on port AB, and CD. The app also supports the TECHNIC Large Linear Motor (Motor no. 2) and TECHNIC XL Linear Motor (Motor no. 3). From the app you can regulate power, speed and position of motors.
· Last but not least, the app has gotten a makeover! We’ve given the interior of the two lobbies a thorough clean-up and made it easier for you to create new projects. We’ve also cleaned up the canvas a bit, and don’t worry, all of your canvas features are still available in the little menu in the bottom right corner.
translate.google.com
Prêt pour un cadeau de Noël précoce? Nous sommes ravis d’atteindre cette étape importante dans notre système numérique en jeu, avec LEGO Powered Up 3.0. Avec cette mise à jour, nous espérons renforcer votre créativité et vous permettre à tous de reconstruire le monde. De plus, nous avons un nouveau look!
Quoi de neuf?
· Pour ceux d’entre vous qui ont plus d’un concentrateur, bonne nouvelle, vous pouvez désormais vous connecter, adresser, coder et contrôler plusieurs concentrateurs (jusqu’à quatre en fait).
· L’application prend désormais entièrement en charge le nouveau matériel LEGO TECHNIC. Vous pouvez maintenant connecter le nouveau moyeu LEGO TECHNIC et utiliser le capteur d’inclinaison interne ainsi que les nouveaux moteurs LEGO TECHNIC. Pour les vrais technophiles, l’application peut lire les valeurs des capteurs internes (orientation (X, Y, Z) et accélération (X, Y, Z) du TECHNIC Medium Hub (Hub128). Depuis l’application, vous pouvez coupler des moteurs sur port AB et CD. L’application prend également en charge le grand moteur linéaire TECHNIC (moteur n ° 2) et le moteur linéaire TECHNIC XL (moteur n ° 3). Depuis l’application, vous pouvez régler la puissance, la vitesse et la position des moteurs.
· Enfin et surtout, l’application a fait peau neuve! Nous avons nettoyé l’intérieur des deux halls et nous avons facilité la création de nouveaux projets. Nous avons également nettoyé un peu le canevas, et ne vous inquiétez pas, toutes vos fonctionnalités de canevas sont toujours disponibles dans le petit menu dans le coin inférieur droit.
génial cette mise a jour!
Un super guide pour vous aider…
Une version simplifiée…
